Remove door 1984 T/A
Old Jun 22, 2011 | 07:44 AM
djjon76's Avatar
Car: '84 Trans Am
Hi all.
Whats the easiest way to remove the doors on the above?
I just need to get them off to repair a bit of rust. The bearing / hinge pins all seem ok, it's just a matter of getting it all off in one piece.
I notice the Three bolts on the body (per hinge), can they just be undone and the whole door removed?
Cheers all
Jonno
Old Jun 22, 2011 | 10:20 AM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
Re: Remove door 1984 T/A
Ya just take those bolts out. Funnest part is taking out the electrical loom. honestly if you can fix the rust on the door with it on the car that is what I would do. Its a pain in the *** to remove and replace the doors without them getting misaligned
Old Jun 23, 2011 | 04:43 AM
djjon76's Avatar
Car: '84 Trans Am
Howdy.
Cheers for that. I don't think I can. The rust is on the underside of the door and a bit on the inner side, where the hinges are. So I really need to get it off, remove the rust, kill it off and patch it up. Its about the only spot on the whole car where the rust is an issue. The rest is pretty much surface stuff.
colton_carlson
Mar 8, 2019 12:21 PM
suzuki949
Aug 28, 2015 08:07 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
BrianI
Aug 9, 2015 11:52 AM
