Sub Frame Install UMI ?
Old Jun 24, 2011 | 07:54 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I need to install my UMI sub frame connectors. The instructions say to load the suspension. I am guessing someone here has some tricks to do this right and I was hoping for some suggestions.
Here is what I own I can probably borrow more.
2 jack stands
2 Jacks
1 dual post lift
2 ramps
Old Jun 24, 2011 | 08:01 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Sub Frame Install UMI ?
Easiest way in your case would be to put the front wheels on the ramps, and then jack up the rear and put the jackstands under the rear axle. Unless your lift is the drive-on type, or is capable of supporting the car by the front control arms and the rear axle.
Old Jun 24, 2011 | 08:08 AM
midias's Avatar
This is what I got. Your plan is what I thought of doing but I was gonna raise it up then lower it down onto the stands and such so I can easily try to get the height level.
Old Jun 24, 2011 | 02:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I agree using the lift to set the car on the ramps and jack stands is the best way to do it. To use a lift for SFC's you really need a drive-on type lift.
Old Jun 24, 2011 | 03:14 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
What i did was pick it up on the lift. Mock up where they go to get the paint off. Then put a cinder block under each wheel and lowered down onto them so the car was perfectly level. Then i welded them in about 50-75% of the way in, then lifter her back up and finish welded
Old Jun 27, 2011 | 09:51 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I would avoid using cinder blocks. I've had several crack while using them to support my old Dodge Daytona. IMO, they aren't safe at all for supporting cars.
Old Jun 27, 2011 | 09:51 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah thats what I did used the lift to lift the car then put it on jackstands...was going to use my neighbors drive on rack but rack was occupied
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
