'83 GFX fitting problem
I have an 83 Z28 over here in the uk.
Been working on getting it back together after a huge stripdown and need some small parts that I cant find over here
I need the nuts the hold the GFX panels on the doors? any idea on part numbers or correct description so I can search the net?
I also need the round disc that slips over a stud on the rear quarter panel that the GFX the fits under the door and on the shell slips over?
Every one I have found searching on here is a bolt on but are held on at the rear by slipping over two metal discs.
Needless to say my one are rotten !!!!
Any help would be great as it is really holding me up now !
CamaroBeav
CamaroBeav
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: '83 GFX fitting problem
Welcome to TGO.
The nuts used on the door GFX are 10mm.They are the same as used on your Rr spoiler.
The round plastic disc used on the Qtr panel is hard to find here in the states.Best bet is maybe fleabay! Not sure what ya mean by "on the shell slips over", but if your refering to what the disc fits onto the GFX.Its two metal brackets with a sorta U channel.The discs slip into that U.Also kinda hard to find as GM only used up 86 or so.
Street Lethal
Apr 30, 2019 12:14 PM
