Door Hindge Replacement
Old Jul 13, 2011 | 05:47 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
What will i really need. Im going to buy from TDS and get the lower and upper hinge kit. I was thinking of pulling off the doors and doing it that way. Or should i invest in the tools he has for sale and try it with the door already on the car? Seems like a lot of tools to get.
Thanks,
Joey J.
Old Jul 13, 2011 | 06:30 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Re: Door Hindge Replacement
It is soooo much easier to take the door off. Get a buddy to help. Get a floor jack, put a 2x6 across it , have your buddy hold the door, jack the jack just enough to put pressure on the door, unbolt the hinge, roll door away. Obv reverse to put it back on.
Old Jul 13, 2011 | 06:32 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Ok thanks dude. So will i even need those specialty tools?
Old Jul 13, 2011 | 06:53 PM
Car: 87 Iroc
Engine: 350tpi
Just make sure you have a socket and ratchet or normal wrench that fit the bolts.
Old Jul 13, 2011 | 06:54 PM
Car: 87 Iroc
Engine: 350tpi
Oh tip, unplug the door harness from the car before you unbolt it, makes life easy
Old Jul 13, 2011 | 06:56 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
what about changing the pins and bushings on the hinges themselves? Taking the door off wont be a problem. Its replacing the parts themselves
Old Jul 13, 2011 | 07:01 PM
Car: 87 Iroc
Engine: 350tpi
I dont see why you would need anything specialty.... But since my thirdgen is currently at the pipe shop, and cant tell you for sure. Best I can do is tell you fri/sat when I get my baby back.
Old Jul 14, 2011 | 10:29 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You'll need a drill with successively larger bits to remove the upper pins, they are peened over (I think that's the right term, like a very large rivet) to keep them from pulling through the holes. I removed the door and used an angle grinder to remove the head of the pin, then punched it out.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
