Tranny mount help!!!
Old Jul 23, 2011 | 04:56 PM
jaypug92's Avatar
Car: 92 pontiac firebird & 92 camaro RS
Engine: 3.1 LHO V6
Transmission: Auto trany M5-A4
Ok here's my story I have a 92 firebird RS convertable and two days ago I noticed that every time I put the pedle to the floor the tranny hits under neath the car so I jacked it up and found out the the mount was broke and the two bolts that you reuse are missing so dose anyone no the bolt size and the thread size? I went to autozone they told me they didn't no so i'm lost can anyone help me?
Old Jul 23, 2011 | 05:26 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Tranny mount help!!!
take youre new trans mount to home depot to the bolt section and keep trying bolts until you find the size that fits. be sure to get grade 8 or better bolts.
Old Jul 23, 2011 | 06:20 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
Thanks man it's two 14mm grade 8 bolts
Old Jul 23, 2011 | 06:26 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by jaypug92
...I jacked it up and found out the the mount was broke and the two bolts that you reuse are missing....
The two bolts, mount to trans are M10x1.5x35. If you use a rubber OE mount, the mount to cross member nut should come packaged with the mount.
JamesC
Old Jul 23, 2011 | 07:01 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
I have the nut just don't have the bolts but now I no what to get thanks @jamesC
Old Jul 23, 2011 | 07:27 PM
JamesC's Avatar
I have to nut just don't have the bolts but now I no what to get thanks @jamesC
The standard mount should only have a single bolt/nut holding the mount to the cross member--or is your car equipped with that awful oil-filled monstrosity.
EDIT: If you have a standard mount, it will look like the ones in the following link:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Old Jul 23, 2011 | 08:31 PM
jaypug92's Avatar
Engine: 3.1 LHO V6
I have a standard mount and the nut I just need the two bolts to bolt it down the must of fell out over time
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
