Repop fenders wont fit HELP!
Car: 84 Camaro T-top
Engine: 350cu Interceptor
i bout some reproduction fenders form a local auto body supply company and they don,t fit, line up or even appear to be stamped right, one is a keystone platinum and the other is GHL, any ideas
Last edited by Feroluce; Aug 27, 2011 at 02:30 PM. Reason: so bleep cant spell right
Car: 91 firebird
Axle/Gears: stock
Re: Repop fenders wont fit HELP!
i had the same problem kind of. mine had front end damage. insurance comp. had it repaired. i bought the car after this. all aftermarket stamped metel was used. the hood never lined up or the fender. also the door is 3/8 too long on the pass. side . keeping me from lining up the front corner properly. i have put some used original peices on it. what a difference, things actualy fit and line up now
Car: 1987 Trans Am
Engine: LQ9/L92
aftermarket stampings can have their issues, but how do the lower mounts look behind the wheels? on almost every 3rd gen i've had, these points were accidentally used to jack the car up with and always tweaked horribly. unless they're pointing straight down, you'll have a bit of adjusting to do to get things right.
Car: 91 firebird
Axle/Gears: stock
the point of my input is that aftermarket stamped peices are hard to find that actually line up right. better off looking for used fenders that fit. i understand the convenience of new ones, but a lot of the time they just dont fit right
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
I agree, unless you work at a body shop then used GM parts are the way to go.
morrow
Jan 13, 2024 12:29 PM
Drone358
Dec 10, 2015 08:16 PM
New2Chevy
Sep 28, 2015 12:35 AM
