rust help
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
rust help
What's the best way to get raid off rust? I have some on the roof right above the driver pass windows and on the a piller by the front windshield. Also were the battery tray is, and I saw alittle by th passanger side front fender at the top of the wheel.
That the best stuff to use ?
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: rust help
To get rid of it, what you'll have to do depends how bad it is. Just a little surface rust you'll probably be able to get away with sanding, grinding, or a wire wheel and then painting. For bad stuff you'll have to cut it out and then weld in a replacement piece.
If you just want to try and stop it from spreading you can get a rust encapsulating product like por-15 or rust mort and cover it with that.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: rust help
Get it clean if the metal is good I use POR15 then prime and paint if the metal is bad I cut weld POR15 then prime and paint.
Engine: 350 carb
Re: rust help
Yea I want to stop it from spreading, I'm not going to paint it for at lease 6 months. So por-15 should work?
Re: rust help
http://www.por15.com/SUPER-STARTER-K...ductinfo/SSKB/
Engine: 350 carb
Re: rust help
So I should clean off as much of the rust as I can right? Then use por-15?
[MN] S&W 8 point rollcage
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
