getting rid of t tops
Old Sep 11, 2011 | 12:51 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I have a t top car that needs new floorpans because of the leaks. I could seal the tops and fix the pans, but I honestly want a hardtop car again.. i dont like t tops on the thirdgens. Is there a way to fill in the top portions without replacing the whole roof? I was thinking that this would give me even more structural enforcement than a true hardtop car would have. Thoughts?!
Old Sep 11, 2011 | 01:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: getting rid of t tops
im sure you could get creative and graft the section from ahardtop car in, but IDK if it would be any "easier" than swapping teh whole roof.
FWIW, solid rollers are cheap, you could always save yourself the headache of the floor pan and roof job by just using different chassis and swapping your good parts over.
Old Sep 11, 2011 | 06:31 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Old Sep 11, 2011 | 06:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
probably cheaper and easier to just get a hard top roller....
Old Sep 12, 2011 | 08:57 AM
1 Quick T/A's Avatar
Car: 92 Firebird
Axle/Gears: 3:42
Now their is a different project. The amount of work grafting in steel panels would be a lot. Also I wouldn't think the use of much bondo would be a good idea because of the normal flexing these cars do. I'd say a solid roller with a good top.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
stalkier
Aug 21, 2015 01:54 AM
