door mirror
Old Nov 8, 2011 | 06:22 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
door mirror
my car has the manual side mirrors on it and the driver side one is loose and i mean the the mirror itself. i can move it to where i need it then when i get up to 60 i guess the wind however its hittin it is moving it so i cant see out of it. is there any way to tighten up the wires that run to it or something
Old Nov 8, 2011 | 07:21 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: door mirror
Would be nice if you could do it from the outside. You will have to take the door panel off, there are two bolts you will be able to get to once you have the panel off. Tighten them up. Be careful when taking the panels off, the plastic fasteners are made cheap. They brake easy. They have a tool you can use to get the fasteners away from the door frame. If you are careful you won't need it. Take your time.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
