bolt in fuel cell?
Old Nov 13, 2011 | 07:06 PM
ChevyRS-305's Avatar
bolt in fuel cell?
Anyone know of any fuel cells that bolt up or are close in dimensions to a factory one thats able to fit in the stock location?
Old Nov 13, 2011 | 09:46 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: bolt in fuel cell?
Ed quay makes some cells/brackets to fit nicely in the 3rd gen.
Also http://www.fuelsafe.com/store/sa114.html
http://www.nastyperformance.com/FuelSystems.html 4th gen tanks are basically the same aside from filler neck.
Not sure if you understand this but stock fitting fuel cells usually cost a lot. It usually comes as some what of a shock to people when they see a 1,000-3,000$ price take on a pretty box made of aluminum.
Best, most cost effective option is to sump a stock tank. If you don't want your old tank new tanks are pretty available and less then 200$. Competition Engineering C4041 sump kit is simply installed into the tank, if you cant do it yourself most metal shops will be able to do it for pretty cheap.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
