Rear hatch motor need help
Old Nov 23, 2011 | 11:15 PM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Will the 91-92 hatch pull down motor fit the 89 Camaro I have the old style that has the wide bushing and there wore out and it won't pull down all the way with out putting a hose to get it to suck all the way down now it's draining my battery so will the assembly that takes the small bushing in the late 91-92 models since it is a better design Im not sure if it fits the older harness and bolt up currently I have the old style with the trunk pop switch in the center console and does anyone now why the hatch motor will drain my battery thanks
Old Nov 23, 2011 | 11:52 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Rear hatch motor need help
No. Mounting pattern is completely different. I suppose you could cut out your hatch motor mount, then cut out the hatch motor mount from a late 91-92 car and weld it to your car. Swapping the hatch hook and re-wiring the car for the newer pull-down motor will be easy by comparison.
Lon
Old Nov 24, 2011 | 09:37 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Lon
Or he could swap to the old style (non-electric motor) style.
Old Nov 24, 2011 | 09:38 AM
ninetyone's Avatar
Axle/Gears: 3:42
You could pull the fuse from the fuse box too. It is called "lid".
Old Nov 24, 2011 | 10:45 AM
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I pulled the fuse but I like to use the hatch just don't know what could be causing motor to keep drawing power
Old Nov 24, 2011 | 02:26 PM
ninetyone's Avatar
Axle/Gears: 3:42
there is also a relay back there,just unplug everything. I would just convert to a regular slam type hatch.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
