New rust on roof
Old Dec 25, 2011 | 01:06 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
New rust on roof
My paint began to chip away little by little on my roof. In the recent weeks, it has rained and I noticed a redish spot on my primer exposed roof. I know I have to buff it out with fine grit sand paper or with steel whool. But is there any spray can or other form of spray that will prevent the rust? Or even better, is there a spray paint that will seal the roof from the elements?
rust2.jpg?t=1324795591
rust1.jpg?t=1324796712
Old Dec 25, 2011 | 01:18 AM
hoogiesngrinder's Avatar
Car: 1989 Camaro IROC-Z Convt.
Engine: 355
Axle/Gears: Zexel Torsen 3.42
Re: New rust on roof
You're in for a bit of work but nothing terribly difficult. Sand down with an orbital. If you hit metal (more than likely) then a light coat of etch primer, primer, filler primer, sand, sealer, color, then clear. Each step will need to radiate from the problem area...blending can be a major pain though.
Old Dec 25, 2011 | 01:35 AM
I dont wanna blend. Im gonna get her painted in like 2 years. I just wanna get it sealed as a temporary fix.
Old Dec 25, 2011 | 01:52 AM
Engine: 355
If that's the case, I'd go down to metal (already compromised), etch, seal, and single stage acrylic urethane. You live in CA, I'm in MI...totally different environment. Hell, out there you could sand it and rub it with 50/50 used motor oil and kerosine and be OK. That's a rust proof seasonal undercoating where I live
Old Dec 25, 2011 | 02:17 AM
Yeah. Doesnt rain much here. So by keeping it with a light coat of oil should be ok?
Fireslash
Apr 11, 2016 06:43 PM
LC2 TECH
Oct 13, 2015 11:53 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
tcflint
Sep 27, 2015 05:58 PM
