What's the reason for common rust areas?
Old Jan 3, 2012 | 09:36 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I know of the certain ares that are prone to rusting like the floors, the firewall, the wheel well lips, and the spare tire area. I want to know why these are the common areas? Any ideas? When I bought my camaro, my pare tire area was perfect. Now it has a hole, and I know it will grow. I just want to know the cause, and maybe I can stop it. Any ideas at all?
Old Jan 3, 2012 | 10:34 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: What's the reason for common rust areas?
Exposure to salt and moisture. I am from Ohio and this is a big issue there but my latest car I bought in NC and has no signs of rust.
Old Jan 4, 2012 | 04:50 AM
chevydrvr's Avatar
That does make sense. Atleast this year they haven't needed salt yet! Or even the plows for that matter. Well, I assume washing the underside every now and again would help slow it down. I just need to fix the holes I had. If I could weld I'd be done.
Old Jan 4, 2012 | 07:48 AM
fbodylove84's Avatar
Wash and undercoat just where water is splashed into especially the original mud flaps are a bad area
Old Jan 6, 2012 | 02:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
A lot of the reasons for the rust in some of those places are due to the ancient body seam sealer they used at the factory. I know that a lot of cars have problems behind the kick panels as well, and I know that there is a problem with the front end of the rockers, where the metal bends come together, that the seam sealer has busted off of. I had the same problem in the driver's rear stowage compartment where about 6 sheet metal panels come together that form the wheel well (I used to get about an inch of water back there driving in a decent rain!). I'd guess that this is a common problem, with the seam sealer breaking off after getting hardened and vibrating loose due to driving conditions.
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
Stryker412
Sep 7, 2015 09:11 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
mrdevontay
Sep 2, 2015 08:04 PM
