4gen gas tank swap questions.
Old Jan 7, 2012 | 05:44 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yep, more questions. Ive searched n searched, but I have not found the answer to two questions.
1. When using AN fittings, how long of hose is needed between the tank and the rubber hose on the 3gen fuel line?
2. I am TPI, no engine swap. Will the 3.8 pump, or LS1 pump be enough to run my TPI. The tank I ordered did not say what engine it was from, will need to investigate when I get it.
Old Jan 7, 2012 | 08:58 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: 4gen gas tank swap questions.
LS1 pump will do fine for the TPI (volume-wise). It will run the pressure too high, though, if you have a tank with the internal regulator. (You may have read some about this already, if not, let me know.)
Not sure about the 3.8 pump though, someone else should be along to comment on that and the hose length...
Old Jan 7, 2012 | 09:44 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
https://www.thirdgen.org/forums/ltx-...third-gen.html
go to "fuel system links"
Old Jan 8, 2012 | 08:47 AM
Dale's Avatar
Engine: 350 S-TPI
Most of them threads I had seen.
None say what length hose.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
