Worth saving?
Old Jan 14, 2012 | 03:10 PM
lonesomeloser's Avatar
Car: 1983 Z28
Worth saving?
In the process of sanding the car down to metal. On the driver side, the key hole is very distorted and extremely thin. The whole area around the hole is depressed with several deep indentations. I removed quite a bit of filler. I knew there was some filler there because it had cracked and was showing rust from the outside. Also the lock cylinder was loose. If I was to attempt to reshape to area again with filler, would it be worthwhile? Or should I find another door? This is my first time doing any sort of bodywork or paint
https://www.thirdgen.org/forums/pict...ictureid=29666
https://www.thirdgen.org/forums/pict...ictureid=29667
Old Jan 14, 2012 | 09:19 PM
toomany's Avatar
Re: Worth saving?
Repairing the area with filler is not the way to fix it. You've seen the results of doing that. If the metal is real thin, then the proper way would be to cut it out and weld in a patch. A new door skin or new door. I prefer to do a patch. A new door would be easier/faster (if you could find one in good shape). Even though all doors are the same, I've found they never fit as well as the one original to the car.
Old Jan 14, 2012 | 09:56 PM
Car: 1983 Z28
Re: Worth saving?
I figured the filler wouldn't work. A patch is beyond my capabilities. So I will get another door. It's a shame.
Old Jan 15, 2012 | 09:14 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Worth saving?
take it to a body shop, theyll charge maybe $100 tops to patch it. it wont take them but maybe an hour since you already have the paint stripped out of the way.
Old Jan 16, 2012 | 08:00 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Worth saving?
How can you say with any certainty that the charge will be $100 "TOPS"?
Old Jan 16, 2012 | 11:52 AM
travis401's Avatar
Car: 91 Camaro RS
Re: Worth saving?
because anyplace trying to charge more than $100 to weld in a simple small patch is just price gouging. most shops charge $60-$80 an hour and it shouldnt take any decent metal worker more than an hour to weld in a patch. even less if you go to the junk yard and cut the piece of door skin to replace your damaged one yourself.
Old Jan 16, 2012 | 06:10 PM
Hipster's Avatar
Re: Worth saving?
I don't think any bodyshop would supply the piece and fix that for 100 bucks
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
