Possible to convert Firebird to Trans Am?
Old Jan 22, 2012 | 11:48 PM
c0wcommander's Avatar
My local CL has someone parting out their 87 Trans Am, will the body parts fit onto a 85 Firebird to make it look like a Trans Am?
Old Jan 23, 2012 | 06:34 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Possible to convert Firebird to Trans Am?
Yes, you need the bumpers front and rear. You also need the door molding and side skirts which will need holes drilled in the doors and rockers to mount. If I were you Id make a formula clone or alteast get the doors off the car being parted out so its a few less holes you have to deal with.I went from a 84 trans am to a 88 formula look. Im not sure how you are going to attach the rocker covers. Mine had braces spot welded to the body that I had to cut off and plug weld.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta power
Aug 13, 2015 06:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
