4th gen spoiler mod
Old Jan 24, 2012 | 10:37 AM
squiggy2's Avatar
Car: 89 GTA Trans Am
Engine: L98/383 stroker
Axle/Gears: 323
4th gen spoiler mod
Does anyone know if the 2 short center legs are hollow? Thinking of sanding them completely off but I am curious if they are hollow as you get closer to the main body. I saw a blue Z on here that had it done and it looked bad a$$.
Old Jan 24, 2012 | 10:39 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 4th gen spoiler mod
The complete wing is hollow.
Old Jan 24, 2012 | 10:41 AM
Car: GTA
And the 93-97 fits, the 98+ doesn't, sort of. It will go on, but the forward wing "feet" & the 2 center supports are angled so it doesn't sit flat.
Old Jan 24, 2012 | 10:48 AM
squiggy2's Avatar
Axle/Gears: 323
The one i picked up is a 2000, your rite about the center feet being angled, most people i have read about dont use the center feet, just for looks but not bolted down, i figured i could remove them, the front of the forwards just need a slight trim and then it will sit good.
Old Jan 24, 2012 | 11:09 AM
Car: GTA
Originally Posted by squiggy2
......the front of the forwards just need a slight trim and then it will sit good.
I thought so too when I got "LS" wing. Being hollow, if you try to trim enough to get it flat like the "LT" wings? You'll end up with no bottom there, which means 2 things.....Trash can or fiberglass work.
Old Jan 24, 2012 | 11:33 AM
squiggy2's Avatar
Axle/Gears: 323
Ok, i got ya, i figured on glass work any way but i defenatly dont want thebottom to drop out, maybe i will extend the legs, depends, I only gave a bill for the spoiler. Would not be out to much.
Thanx.
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
AkDrifted
Aug 17, 2015 07:45 PM
