Hatch glass bolts?
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Hatch glass bolts?
On the rear hatch, the bolts that run through the glass at the top. The protective coating (not sure if it was plastic or some kind of hard enamel paint) has chipped away and are now rusting away and putting rust streaks down my back glass
. Got any tips on where i can get replacement covers/bolts or what i should do?
. Got any tips on where i can get replacement covers/bolts or what i should do? Joined: Aug 2011
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Hatch glass bolts?
I got mine from another third gen at U-Pull-It. Bet you can find them at Pick-N-Pull too. They looked almost new!
Car: Camaro 1987
Engine: V6 2.8l MPFI
i was thinking, if you put quicksteel and molding the cap u can probably get the shape right? and then paint them
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
New ones available at Modern Day Muscle
http://www.moderndaymuscle.com/inc/sdetail/163/858
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
