90 camaro ground effect removal help!
Old Jan 27, 2012 | 09:58 PM
coreyc1210's Avatar
Car: 1990 Camaro RS
Ok i got all the screws out for the side skirt but the back part of it will not come off, i even took the interior panel out to get to it or something ya was not happening a one, so how do you get the darn thing off?
Old Jan 27, 2012 | 11:31 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: 90 camaro ground effect removal help!
Id like to know too.
Old Jan 28, 2012 | 12:33 AM
TheEndofanEra's Avatar
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
In order to get the bracket off the car, you'll have to take out the speaker and trim plastics, and reach down inside there (its a lot further down than you'd think) and undo the 10mm nut that holds on the ground effects.
The alternative, if I recall was to slide the ground effects up or back, I don't remember which, in order to get it to slide off without having to unbolt the bracket from the car.
Old Jan 28, 2012 | 10:33 AM
Steve86TA's Avatar
Car: To many to list
the only interior part you need to remove is the lower section next to the rear seat but under the speakers.Once you remove that you will probably have a small piece of the black rubber insulation covering the hole that you need to access the bolt.Once you remove or poke through the black rubber you will see the stud/nut ..
Old Jan 28, 2012 | 10:59 AM
coreyc1210's Avatar
Car: 1990 Camaro RS
That black rubber ur talking about i looked right at it, i kinda figured it was behind that, but alright well that explains everything thanks!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
3rdgenparts
Aug 8, 2015 07:09 PM
