88 Gta interior door panels
Old Feb 3, 2012 | 11:09 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so my 88 Gta has a set of 86 trans am doors with the big long thick arm rest. the previous owner gave a set of black Gta door Panels with cup holders, brackets, arm rest an door handle cover plastics with the bird emblem. I'm looking into putting these door panels on these dOors can it be done or do I have to find 87-92 trans am doors an put those on them
Old Feb 3, 2012 | 11:24 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 88 Gta interior door panels
The only difference between the "GTA" dooors & "non-GTA" doors is the bracket for the arm rest. If you can get it in the correct spot for the arm rest, everything else will line up just fine.
Old Feb 3, 2012 | 01:33 PM
User Error 87's Avatar
Car: 1987 Trans AM GTA
Engine: 5.7 TPI
Axle/Gears: 3.73 POSI
wow i never knew that...i would have thought that the door wouldve been the same.
Old Feb 3, 2012 | 01:46 PM
Car: GTA
That it was I said....Same doors. Just an extra bracket for the different arm rests.
Friend of mine bought a GTA door from me, took the arm rest bracket off & put it on a Camaro. Swapped out the ground effects pieces & he was done.
Old Feb 3, 2012 | 04:57 PM
Engine: LR4 4.8
This will be awesome so pretty much just gotta bolt up the arm rest to the bracket an bolt it to the top an then just drill through the holes an it should line up I think
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
