Front bumper cover dent
Old Feb 6, 2012 | 07:09 PM
Starbug's Avatar
Car: '89 Firebird Trans Am WS6 - project
Engine: Building a 400 C.I. SB Chevy V8
Transmission: manual T5
Axle/Gears: posi rear end
I did a search for restoration of the front bumper cover, and turned up ways to fix a crack or hole in the bumper cover. I have some holes to fill, so they were good reading. But I have another problem....
The top middle of the front bumper cover, just to the side of the bird sticker, has a slight dent as if somebody sat on it. Is it possible to fix a dent (sagging?) in a urethane bumper cover? I'm wondering how it might respond to a heat gun and then cooling it in the proper shape. Has anyone tried this, and did it retain it's back-to-original shape after the summer sun hit it?
Thanks!
Old Feb 6, 2012 | 07:43 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Front bumper cover dent
https://www.thirdgen.org/forums/body...g-bumpers.html
Old Feb 6, 2012 | 08:33 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
i read that link and i didn't see MY solution on there....maybe somebody else did it too, who knows? but what i did was take the bumper cover OFF, turn it up side down , rough up the area that was sagging ( back side only) and Glued a piece of aluminum plate to it with high strenght epoxy....while it was setting up i put a 30 pound dumb bell on it...i did one side per night....so it gets nice and flat on your floor......now it CAN'T sag..mine looks good now for the last 4 years or so.....
Old Feb 6, 2012 | 08:54 PM
Car: 91 z28
Transmission: 4L60e
If you use heat to move it back into place, as soon as it gets hot outside the sag will return. The basic idea in the thread is to somehow make a rear reinforcement for it. Another solution would be to use plastic glaze (filler), however, this would require a repaint.
Old Feb 6, 2012 | 09:13 PM
Starbug's Avatar
Cool, thanks guys! You must have used a better search term than I did, lol. Looks like an aluminum reinforcement is the way to go with this problem.
Home Depot, here I come....
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
