82 Trans Am Lower Door Seals
Old Feb 12, 2012 | 05:07 AM
diabolik's Avatar
Car: 1982 Pontiac Trans Am (Recaro)
Engine: 5.0 v8 (305 TBI)
I bought a set a while ago and have never really been happy with them, mainly where the screws go in on either end, it seems the once you put the screw though the seal to the car and but a bit of tension on it pops off, even with a washer on it still does it now the connectors around the seal are popping off seems the rubber is too soft.
Have i bought the cheap set? or just a bad set any advice would be great as now looking for a more solid set
Old Feb 13, 2012 | 06:13 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 82 Trans Am Lower Door Seals
the original GM seals had a plastic insert that kept things a bit more sturdy around that screw. unfortunately most of the aftermarket ones do not. if you're having issues keeping that section in place, it may help to put a dab of weatherstrip adhesive between the seal and the door panel and then install the screw to keep things in place while curing.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackTopKing
Aug 19, 2015 12:13 PM
Exxon Limited
Aug 9, 2015 08:13 PM
