Help with window problem please!
Old Feb 15, 2012 | 12:40 AM
alexquade's Avatar
Car: 1992 RS
Okay, i had to replace my driver door today due to an accident i had a while back. Replaced the entire door/hinge set up. Well, everything lined up right until i took her down the road. The VERY TOP of the door is slightly bubbled out. Like, an inch worth of it, and the back of the window isnt against the seal. The top meets, tho. its pretty much the middle of the window that doesnt touch. At all. Lets wind in and whistles like crazy. Do the hinges need to be adjusted? If so, how???.... Or is it the window that needs adjustment???.. Im lost. I HONESTLY dont know how to adjust the door the way it would need to be adjusted.
Its a 1992 camaro rs. The donor car was a 91 firebird.
Thanks in advance!!
Old Feb 15, 2012 | 02:55 PM
chrispy383's Avatar
Car: 92 rs 25th ann.
Engine: 383
Axle/Gears: 342
Re: Help with window problem please!
There are three adjustment bolts for the window, you will have to take all of the interior off the door to get to them.
Old Feb 15, 2012 | 03:00 PM
alexquade's Avatar
Car: 1992 RS
So it is my window that needs adjustment?? Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
