Blocks for Sanding
Old Feb 18, 2012 | 04:19 PM
reefland's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L
Blocks for Sanding
I am getting closer to doing final preparations on the body for paint. That final prep will be the block sanding but I first need some blocks. Leave a reply letting me know which blocks you're using and where you got them.
Old Feb 18, 2012 | 06:22 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Re: Blocks for Sanding
Dura block
Eastwood adjustables
Eastwood for all
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Get these: http://www.eastwood.com/7-piece-sanding-block-kit.html
I've used these for years....they're great
Old Feb 19, 2012 | 12:32 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Motor guard, I believe they are new to the market. They are comparable to Dura block.
I use 3m blocks. They are free with a box of paper. I just checked out Dura blocks web page and noticed that they are starting to be compatable with 3m paper. Keep in mind what paper you would like to use, as generally most blocks (exept 3m) use stick on paper. Note: As of this month 3m hook it 2 is now obsolete.
I have one block that I cut out of a broom stick (lenth of a 6" DA sanding disk), it works great for tight curves.
Another trick for tight areas is to wrap a 6" DA around a scuff pad.
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Jul 23, 2018 08:47 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
RyanJB
Sep 14, 2015 03:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
