Help. Gas cap stuck.
Old Mar 5, 2012 | 06:24 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I believe someone may have messed with it, possibly put glue or sealant on the threads. No matter how I turn it, it clicks. I don't want to ruin my fill neck. Is my next step to crush the cap with channel locks?
Old Mar 5, 2012 | 08:27 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Help. Gas cap stuck.
id probably screw a screw through it about a half inch from the center.
Old Mar 6, 2012 | 02:42 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
This should lock the cap together as one piece and stop the clicking. If need be then I would carefully use channel lock pliers. I would try to keep from crushing the cap as that could put pieces of the cap in the tank. Though I would think it would be unlikely those pieces might eventually damage the fuel pump pick up screen or 'sock'.
Old Mar 6, 2012 | 05:24 PM
Mr Froman's Avatar
Thanks guys. Drilled two shallow holes near eachother and put screwdrivers in each hole. Worked great.
Old Mar 11, 2012 | 08:31 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
For future reference, this shouldn't be an issue since the filler neck has the spring loaded door to keep foreign bodies out of the tank.
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
Andrew6.688
Dec 13, 2015 10:59 AM
chazman
Aug 22, 2015 02:01 PM
