metal lip around windows
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
hey just picked up a 86z an it has this ugly thin metal lip on the roof that follows the window outline is there an ez way to remove this?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: metal lip around windows
its it removable, yes. is it easily removable...no. its gonna require some cutting, some welding, some grinding, some body filler, and paint.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
On my 85 IROC, the drip rail is held in place with several screws underneath the weather stripping.
JamesC
JamesC
No grinding, filling... It is the drip rail. You may need a little paint after removal, depending on how it was painted, but remove the upper window seal, unbolt the seal track and you will see the drip rail. It is either screwed in or glued on, but is easily removed.
MrPackstin
Oct 25, 2017 08:09 PM
bigjay89gta
Oct 15, 2015 08:04 AM
