91-92 hi rise wing pic's and question
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
anyone with a pre 91 camaro that has ground effects please post pictures of your car if you mounted a 91-92 z28 wing.if its black that is a plus for me.
now for the question.
i have an 88 with the shorty wing and i see that the 91-92 wing uses the same center holes as the shorty wing. should i use my deck lid of buy a new one that has all 4 mounting holes already drilled?
next question,
were do i get the gasket that goes between the deck lid and wing for the 91-92?
next question,
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 91-92 hi rise wing pic's and question
about 1 1/2 years ago i had mine off for full paint job . the end gaskets i found (i think) at MDM . the center ones i could not be found . i ended up cutting small rubber washers from some sheet rubber . the 2 center posts set about .035-.040" above the skin of the deck . my rubber washers can't be seen . worked for me , good luck .
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I believe Hawk's sells the gaskets.
