Axel info please?
Old Apr 15, 2012 | 01:39 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Axel info please?
i keep seeing in people's profiles about having
Axle/Gears3.73 what does this mean?
Old Apr 15, 2012 | 01:53 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Axel info please?
that is the "ratio"of the axle-the number of times the
pinon gear or driveshaft must turn to make the ringgear
or drivewheels turn one time
Old Apr 16, 2012 | 12:32 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
the higher the gearing the more low end torque you will get. The lower gears like the that came with most later model v8's 2:73's are for fuel economy.
Old Apr 16, 2012 | 12:48 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
You can jack up the vehicle and chalk mark both the driveshaft and wheel and do one full revolution with the wheel while counting aproximately how many times the driveshaft did spin. 3 spins would be a 3.08 3.5 spins of the driveshaft would make it a 3.42 etc.. this only works on a posi traction rear end. On an open differential, jack up the vehicle only enough that one wheel stays on the ground and you need to rotate the tire two times.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
