Rear Hatch won't open
Old Apr 28, 2012 | 12:39 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
My rear hatch won't open. worked fine a couple days ago. It has a pull down motor but of course it doesn't have the power release on the inside. Also will not open with the key. The only thing I can think of is to crawl into the car, pop the light out to access the cable to try and get it to open so I can pull the panel to see what the hell is going on.
Does anyone have any other suggestions?
Old May 1, 2012 | 10:48 PM
ZeBatmobile's Avatar
Car: 92 Z28
Engine: 350 (ZZ4 Block) '193 heads.
Transmission: WC T-5
Axle/Gears: 3.42 Posi
Re: Rear Hatch won't open
try to disconnect the car battery. The pulldown motor has a built in circuit breaker that will pop if its overloaded. Once voltage is disconnected it will reset. I closed my hatch with my rifle in the way and it never opened again. I took everything apart and unplugged the motor voltage connection (two wire on motor) and it began to work! I think it would have been easier to disconnect the batt... if thats not it you need a new motor,
Old May 2, 2012 | 05:51 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Try pushing down on the hatch as you turn the key. The electric motor shouldn't keep it from opening. It should open even if the motor is unplugged.
Old May 2, 2012 | 08:01 AM
Car: 91 Trans Am
Engine: 355 TPI
yeah the cable is stretched a tiny tiny bit. just enough to not pop it with the key
Old May 3, 2012 | 05:51 PM
waterboy87's Avatar
On my 91 RS, I had to cut a big hole in the plastic panel and use a flat blade screwdriver to get it to open. The hole has to be right behind the latch. I also had a key, but it would not work.
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
