Front Passenger Fender Removal Help...
Old May 8, 2012 | 10:21 PM
Jmikesell's Avatar
Car: 88 Camaro, 97 Ford Explorer
Engine: 2.8 V6 for now
Transmission: stock
Axle/Gears: stock
Hello my name is Justin, I just purchased my second 3rd gen Camaro. The first an 89 which I sold and just recently I bought an 88 as a fun summer project.
The 88 was in a very light fender bender, The passenger side fender is a little dinged up I am attempting to remove it and push out the dents. I have removed all bolts too my knowledge. (This would be all the bolts under hood, the bolts behind front bumper and the bolt underneath the car behind front tire and the antenna and the small bolt around antenna.)
The front of the fender is completely free but it seems to be hanging up from the back near the bottom.
What could this be? I have been pushing, shoving, smacking, prying and slamming in all directions (towards back of car and down. Towards back of car and up and Vise versa.)
anyone have any ideas?
Old May 8, 2012 | 10:56 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Front Passenger Fender Removal Help...
It sounds like you got the large bolt behind the wheel near the jacking point, but sometimes people mangle the tab the bolt goes through. It may have another bolt or clip welded there as a repair. The wheel well liner is disconnected?
Old May 9, 2012 | 12:26 AM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
look under the car theres a big bolt holding it on along the pinch weld, they often get pushed up from people jacking that spot so take some pliers and pry it down and unbolt
Old May 9, 2012 | 12:54 AM
Jmikesell's Avatar
Transmission: stock
Axle/Gears: stock
Nope I missed that one. Thanks! Now Idk of its from the torque of bending that peice but that sumbitch is IN THERE. Probably going to have to cut it or drill it out. :/
BlueIroc-Z
Jun 9, 2019 03:22 AM
kyleb24
Aug 15, 2015 08:24 AM
Street Lethal
Aug 14, 2015 08:25 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
