crackled bumper cover
Old May 12, 2012 | 06:41 PM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
How do I best deal with crackle effect on my bumper covers? Getting ready to paint and not sure if I can use bondo, fiberglass filler, or do I have only the option of buying new ones to do it right?
Old May 13, 2012 | 12:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: crackled bumper cover
Bondo/fibrglass will just de-laminate later on, ruining your new paint job.Best to get new/better repalcements.
Old May 13, 2012 | 12:31 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
sanding it smooth then using a bondo for plastics worked on my last z28 and it looked great after three years ...
Old May 14, 2012 | 09:34 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Sand past the damage, (120-220 grit). As you get close to being past the damage start stepping up grits in 100 grit intervals with your final sanding being about 500-600 grit. No glaze (filler) should be needed. If needed "Evercoat Flexible Glaze" can be used.
Old May 14, 2012 | 09:43 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
pretty much what i did... so guys whats the verdict have you tried anything yet... doesn't hurt to keep her original. If your going to trash the part you might as well atleast try your hand at body work..
Old May 16, 2012 | 06:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
My body shop wont repair them,need to get one with no cracks and hopefully one coat of paint.The reason he wont is,it's what the bumper covers are made off,nothing sticks to it to do a proper job.You can get a new after market one from Classic,I'd wait till they have another 20% off sale,that's what I did.
Old May 19, 2012 | 06:13 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
Do you really want to know what I did to fix my crackle and paint peeling on my front bumper.......Yep, a bra. I definitely didn't put it on there for it's looks...lol.
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
jessejames82
Oct 16, 2015 10:11 PM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
codeysabatini
Sep 24, 2015 05:40 PM
SG91camaro
Sep 5, 2015 10:27 PM
