Whats involved in replacing t-top seals?
Old Oct 19, 2000 | 01:49 PM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
My headliner started to sag the other day from my constant leaking of the t-tops. So this winter im going to replace the headliner and seals. What is involved in doing all of this. Are the seals and headliner difficult to replace?
1987 IROC-Z 305 TPI
S/R Torquer heads,Compucam,Edelbrock TES,SLP Runners,52mm TB,Ported plenum & intake,Hypertech Thermomaster chip,plus a bunch of other mods.
Old Oct 19, 2000 | 02:53 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I haven't replaced the headliner yet, but I did replace the t-top gasket. You'll need two tubes of sealer, a scraper (preferably plastic so you don't gouge the paint), and then I used a heat gun to warm the material to make it easier to take off. Make sure that you clean everything out really well, or else your tops will never seal properly. Putting in the new gasket is really easy, but you have to be careful not to get sealant everywhere. I used a tube for both sides, just to make sure that I had enough... Its a pretty straightforward job, but after you do it, I recommend realligning the tops, that turns out to be the hardest part. I actually might be getting it done again, but this time i'm going to have the headliner, kick panels, and the valences replaced also. I really didn't like the job that I did, and it was sort of a hassle, so I'm just going to pay someone to do it.
I guess I'm more of an engine guy, not a bodywork guy though...
Good luck,
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
Old Oct 19, 2000 | 03:15 PM
Wolfcoast's Avatar
https://www.thirdgen.org/newdesign/tech/ttops2.shtml https://www.thirdgen.org/newdesign/tech/ttops.shtml
These will explain both the seals and the headliner for you.
Good luck
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
qz6lwp
Aug 20, 2015 08:10 PM
Leggman1
Aug 6, 2015 04:15 AM
