Hatch lock cylinders
Old May 16, 2012 | 01:00 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Ok, so when i bought my iroc it didn't come with the hatch keys. I went to auto zone and picked up a cheap lock that they say is for a 86 camaro.. lo and behold, it doesn't have the extension to turn the cable on the electric hatch... anyone know where i can get the correct one? I went back and the auto zone guy told me to removr the extension and put it on the new lock.. it looks pretty impossible...
Old May 16, 2012 | 04:00 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Hatch lock cylinders
hmm, you could disasemble both locks and take the whole peice that that extension is on and swap in the new locks actual cylinder and see if that'd work? if thats even possible i've never tried it, the door key should work the hatch? are there different door locks, because mine were switched before i got the car and my key still works the hatch
Old May 16, 2012 | 04:30 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
i have a working set with a key i removed from my 86 iroc. i believe it has the extension you need. i could ship it out to you if you need it. i believe i have pics somewhere. just text me and ill send you pics. #s in your mailbox
Old May 16, 2012 | 05:28 PM
JacobIroc's Avatar
Looking at it, it wouldn't work. Thanks though.
Old May 16, 2012 | 05:38 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Why don't you just go to your GM dealer and give them the VIN number? They were able to cut me a key for the t tops just by doing that. And that same key also unlocks the trunk.
Bethany
Old May 17, 2012 | 12:23 AM
JacobIroc's Avatar
Bethany
I have my T-top key and it would only got about 1/2 way into the lock.. The lock really has seen better days lol. I'm buying one from someone on here.
Old May 17, 2012 | 12:42 AM
kmcn47's Avatar
Transmission: 5spd
how much did it cost to get a new t top key, i need one, my locks are loose when not locked and they vibrate, it drives me crazy lol
Old May 21, 2012 | 06:59 PM
JacobIroc's Avatar
Hmm.. Called Capitol Chevrolet and they said it would probably be 75$ - 100$ for a key... ****k..
Old May 21, 2012 | 08:02 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I really don't think these come apart,I could be wrong but I just don't see it.
I tried to pull on it and there's a spring in their and it looks to be riveted.
Old May 21, 2012 | 09:55 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Not sure if the cable assembly will disasemble, however, there should be a way to get the tumbler to release. Someone, dealer/locksmith who has a master set of pins can re-pin (re-key) the tumbler. Another option is to swap tumblers. All of the tumblers I have had to remove required a key to remove the tumbler, so the tumbler may have to be "picked" if no key is available.
Old May 21, 2012 | 10:00 PM
kmcn47's Avatar
Transmission: 5spd
are the keys universal anyone wanna sell me one for alot cheaper? and mantaguy idk it doesnt look like it, i'd keep hassling the seller for the right part
Old May 21, 2012 | 10:54 PM
JacobIroc's Avatar
Ive already replaced my trunk latch.
@ mantaguy. Mine look much different, the t/a's must be different than the irocs.. with the irocs there is two tabs that hold the lock to the plastic. Using a screwdriver or two. Slide the screw drivers doen the sides between the tabs and lock cylinder.. then just pull it out. Thatd my brief summary. Im going ti research about getting my ttop locks matched to my hatch key. We'll see.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
punkmaster98
Sep 30, 2015 11:01 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
