WINDOWS!!!
Old Oct 21, 2000 | 06:14 PM
PopaPork's Avatar
WINDOWS!!!
Hey I don't know where to put this up at, but I need to know whut I need to switch over from Manual to Power windows. I don't want to get new doors or door pannels. I found plugs for the crank hole. But what do I need, motor and actuator or just the motor. Thanks
Old Oct 22, 2000 | 04:02 PM
87 Firebird's Avatar
I haven't done this, so if I'm wrong, you've been warned...Youd'd need door interior panels, probably a new console panel, unless you want to cut up your one for the switches, switches, motors, heck, you'd be better off to get the doors from a wrecker, and then just swap the insides. At any rate, you've got your work cut out for you.
Old Oct 23, 2000 | 08:45 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Its really easy if you just get doors and ALL related parts off a donor car.
The whole power lock/window harness comes out of the car seperatly with all switches and relays attached.
just hook up your constant 12v, key 12v, and ground and away you go.
If you get everything off a donor you won't have to go looking for the odd stuff like connectors, relays, console trim pieces, etc.
Some people have done it by just switching the guts in the doors, I personally haven't done it that way.
Another option is (belive it or not) JC Whitney sells a universal power window kit.
A buddy of mine installed this kit in his ranger pick up with all the stock regulator hardware and it works really well.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 23, 2000).]
Old Oct 23, 2000 | 09:57 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Eastwood also sells a power window kit it cost around $145. It should be on there web site at www.eastwoodcompany.com
"5 out of 4 people have a problem with fractions"
My Camaro: http://home.earthlink.net/~singleton052095
Old Oct 23, 2000 | 09:32 PM
PopaPork's Avatar
Ok thanks for the help. So I need to take the Actuators that go from the motor to the window out huh?
Old Oct 25, 2000 | 02:38 PM
Viking's Avatar
Car: / 89 IROC /
Does anyone know if GM still offers this as a kit? They did the last time I asked (10 years ago!).
89 IROC original owner, 3 amplifier 8 speaker Kenwood/Infinity sound system, 300,000 miles on original 305 TPI. Change your oil!!!
Jeff's IROC Restoration
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
