Locked out of hatch...please help.
Car: 89 FireBird
Transmission: AUTO
Ok so heres the story. I was in a hurry trying to grab my stuff out of the hatch of my TA bc I was just barly on time for work. I did not have the key in the whole way for my lock cyl for my hatch. Totally snapped the key :/ well....here is my problem the pull down motor is burnt up (been too lazy to change it...oh regrets) How can I get in my hatch? I have a sub box in the back so I cant pull any interior plastics...I have a parts car I can rob a lock cyl off of if I know how to break in to my hatch haha. Thank you in advance
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Locked out of hatch...please help.
Sorry, can't help you, but I am in a similar situation - having a sub box. I disconnected my electric trunk motor because it was broken and draining the battery, and the lock crapped out on me. Subscribed to figure out how to get in my trunk also so I can swap the lock out...
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
If you are not worried about ruining the lock cylinder you can drill out the insides. Then you will be able to unlock with a flat screw driver and remove the old lock.
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
In case of emergency,do not break glass!
Engine: 454-350
1/4 inch should do the trick, as always take your time be patient and let us know how it worked for you!
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
