Rear Coil Noise
Old May 23, 2012 | 07:35 AM
cvicha's Avatar
Car: 91 Z-28 Convertible
Engine: 5.0L
Rear Coil Noise
I have a 91 Z-28 convertible. When I jacked the rear end up to see if part of my suspension was broken (because I was hearing a muffled noise when I hit a bump in the road) I noticed the driver side coil was scraping against the trailing arm (I think) when I let the car down. Should there be a boot or cushion of some sort underneath the coils to avoid this scraping? The passenger side doesn't do it. Thanks!
Old May 23, 2012 | 07:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Coil Noise
Welcome to TGO, cvicha.
There is an isolator on top of the spring. The lower portion of the spring simply sits on the axle without benefit of an isolator.
JamesC
Old May 23, 2012 | 07:41 AM
cvicha's Avatar
Engine: 5.0L
Re: Rear Coil Noise
Thanks for the info. I tried greasing the bottom of the coil. That lasted for about three days and we are back to the noise again. I wonder if replacing the coils would help?
Old May 23, 2012 | 08:26 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Rear Coil Noise
Most likely the rear shocks were replaced and the mechanic didn't get the spring located in the upper spring perch inside the rear frame rail properly.
Old May 23, 2012 | 08:28 AM
cvicha's Avatar
Engine: 5.0L
Re: Rear Coil Noise
Thanks. I will check.
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
BlackBoulder
Aug 11, 2015 11:15 PM
