slamming doors
Old Nov 10, 2000 | 03:05 PM
Pro91Z's Avatar
slamming doors
this is my third camaro and its the same old thing.. slamming the doors shut.. how can i aling<~~(spelling) my doors or where can i go to fix it.. how much will it cost..
thanks for the help
Old Nov 10, 2000 | 05:02 PM
KS91Z28's Avatar
Any body shop should be able to replace the hinges for ya, I'm not sure about the cost though. Or, you can replace them yourself for $150 - $200 (buying the hinges from your dealer).
Old Nov 10, 2000 | 05:51 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can bore the holes and use larger pins, which should fix the problem. An easier, and cheaper way is to shim the hinges. The doors will still have play, but will sit at the proper height.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 12, 2000 | 06:01 PM
86ZRICHIE's Avatar
I know you can repair the bottom hinge, but the top one has to have the welds drilled out and the new one bolted in. GM gives you a backplate to bolt the new one on. I got mine for about $70 and have heard of GM dealers offering to replace and paint the hinges for around $150-250 per side.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
