How do i get the side mirror off?
Old Nov 26, 2000 | 07:43 PM
Sweet_85_Bird's Avatar
I need to get my side passenger mirror off my 85 firebird.How do i get it off to replace it?
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Old Nov 27, 2000 | 12:31 AM
ONEFINE8T9's Avatar
pull the door panel off from inside. There are two 7mm bolts that hold the mirror on. Unbolt them and take it off. Reverse process to take off. Its a good idea to replace the "mirror to door" gasket. They like to take in alot of wax and what not.....imo
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
http://members.aol.com/j007golden/Mikey89.html
Old Nov 27, 2000 | 12:33 AM
ONEFINE8T9's Avatar
oooops! i mean Reverse process to put on.
Old Nov 27, 2000 | 11:41 AM
tdogs88camaro's Avatar
ok first u have to take the door panels off from the inside. after u have that off look directly behind the mirror and u will find two little bolts im not sure what size they are but they are there then take those two bolts out and the mirror will easily come off. a little gasket like piece will come off with the mirror too. keep it u will need it to put the mirror back on.
Old Nov 30, 2000 | 04:33 PM
Fastcamaro87's Avatar
yeah just remove the door panel, then put the window down and remove the 2 10mm bolts that hold it on, if you have power mirrors, theres a connector you have to unplug also.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
buckshot63
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
