Z28 Badges?
Old Dec 9, 2000 | 12:58 PM
leirch's Avatar
Z28 Badges?
Guys, i need to know where i could get OEM badges that go on the rocker groud effects?
I just got my 87IROC not long ago and i need one.
Or is this just a GM product? and do they still have them available?
Thanks,
Brendan
P.S. and yes i posted the exact same message in the appearence forum just to get as much input as possible.
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Old Dec 9, 2000 | 10:34 PM
iroczVinnie's Avatar
Car: 89 IROCZ vert
Engine: 305TPI
You can get this part a classic industries, and you can prob order it from thirdgenresourse.com, or year one's nextgenparts.com as well. Just check arround for the best price
Old Dec 10, 2000 | 11:52 AM
Coolcars's Avatar
Go to ebay and search IROC they have them there almost everyday.
2E,87 Formula 350, 4 other Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Dec 10, 2000 | 11:56 AM
leirch's Avatar
Thanks for all of the help guys!.. I shouldn't have a problem finding it now!
Thanks again,
Brendan
Old Dec 15, 2000 | 02:05 AM
Z28Maniac's Avatar
BTW, you can still get them from your local GM Performance Parts dealer. I bought both side badges and the rear one for my '83 Z28 from a local Chevy dealership a few years ago. They costed $20 each for the side badges and $15 for the rear badge.
John
'85 Z28 TPI 305
Old Dec 16, 2000 | 12:01 AM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
hey you should check out thirdgenparts.com I got a set of stainless steel emblems from them. They are the really sharp and fit perfect just like oem. You can get them to look like factor emblems or even go for the custom look if you wish. I would post pics but I don't have a scanner but I ll try to get some pics. Well check them out
Old Dec 16, 2000 | 11:27 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I got mine from my local GM dealer recently.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side not too bad
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
z28joe2
Sep 28, 2015 05:54 PM
