Looking for a 4point cage
Old Dec 11, 2000 | 11:22 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I just got my hands on a 91 TA conv. I have seen some cages which are designed for clearance and access, but I doubt any of them will fit a convertable. Has anyone ever used any kind of removeable cage? I haven't seen it done, but I figured some type of locking pins could be designed. If nobody sells a cage which would work anyone have some suggestions for a good custom shop to check out.
Thanks for the help.
Old Dec 11, 2000 | 11:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
http://www.cachassisworks.com/
This is chris alston's chassisworks,, I believe they will make you a custom 4pt for a small extra fee. Click on the roll cages link at the bottom
Hope that helps some
Da Boid
- 4 out of 5 people think the 5th is an idiot
Old Dec 12, 2000 | 12:34 AM
Axle/Gears: Drums?
Thanks for the help man. I won't be doing anything with a cage anytime soon, but it's never too soon to get the info. The car is stock right now, but if it gets much faster I'll definitely want some kind of cage.
Old Dec 15, 2000 | 06:30 PM
Axle/Gears: Drums?
Is there anyone with a convertable who has a single bar hoop or a cage they have pics of?
Old Dec 17, 2000 | 11:35 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I have a ragtop as well and plan on installing a custom 6-point cage. It will have a roll hoop behind the seats that will be tied into the rear at the rear seat location. The roll hoop will have a bar running along each door sill low to tie into the front. Removable bar running diagonally from the drivers side of the hoop up high to the passenger side low that is installed only at the track. Also door bars pinned in place at the track only. Allows easy ingress and reclining of the Corbeau Targa RS seats to recline, except at the track. Good luck, Lon.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
Bob88GTA
Sep 10, 2015 09:07 PM
