modify rear firebird markers to make flush fit
Old Jun 24, 2012 | 12:17 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Hello all,
I'm redoing my 85 TA from scratch, totally disassembled. This project is to make a mostly stock TA but eliminating or changing all the little things I don't like.
One thing is to eliminate all the plastic and metal surrounds in the body like the fender vents and hood vents. I changed the fenders to GTA style, changed the 4vent hood to power bulge. Now I'm trying to eliminate the rear marker surrounds. Anyone just welded the metal brackets in and fill the gap?
Any other ideas you've tried?
I have the body completely stripped right now. Eliminating the small amount of floor pan rust, fixing the quarter panel dents and just finished cutting the holes to convert to manual tranny and cut off the manual hatch latch bracket. This week I'm welding the power pull down bracket in and fixing the dent that is right at the right rear marker, so I'm going to try this mod at the same time.
I was thinking of putting 4th gen ones in, but they apparently have a visible screw in them, don't like that either.
Any ideas?
Old Jun 24, 2012 | 05:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: modify rear firebird markers to make flush fit
a friend of mine is planning to swap the rear bird markers out for front markers, using a pair of front marker and the surrounding metal cut from a set of trash fenders. no pics cause its not done, but thats what to do.
buy crap fenders, cut a section out, cut a matching hole in the quarter and weld back in.
Old Jun 24, 2012 | 05:27 PM
stealtht/a's Avatar
I was thinking about that, but then the rear markers would be the wrong color. I have plenty of fenders to chop up.
would red tint work over yellow?
I'm a little **** about lights, illegal light mods are kind of a pet peeve of mine.
Old Jun 24, 2012 | 07:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Use a red bulb in a clear lense
Old Jun 24, 2012 | 07:41 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Just use the VHT lens paint to convert them to red like the Camaro guys use to convert their amber tail light lens sections to red.
Old Jun 25, 2012 | 07:51 AM
stealtht/a's Avatar
Yes the bulb thing won't work since the reflector would still be illegal and wouldn't look right anyway.
The Vht thing was what I was thinking of. The guys on the Jeep forum do the same thing.
Anyone know if I would still need the red bulb or would white look ok?
I'm going to go cut out the fender markers, post some pics when I get them installed.
Thanks for the ideas guys!
Old Jun 25, 2012 | 08:23 AM
Car: GTA
I believe you'd use red bulbs just like the stock red lenses use because I think the white bulb would wash out the red too much. I know BigBadLou has done it & you could ask him (many others have done it just that that the first name that comes to my mind).
I did the VHT Translucent Red mod to my clear Reverse lenses to convert them over to tail lights & used red bulbs.
Old Sep 12, 2012 | 07:50 AM
stealtht/a's Avatar
Quick update on this, I'll get some pics up as soon as I can.
Just wanted to stop anyone else from starting the wrong way as I did.
I cut out the fender light mounts but I made a tactical error in welding in the new ones. I cut out the whole marker mounting section and butt welded the fender piece in. Unfortunately, I didn't notice the fender material is thinner than the QP sheet metal. This means it gets out of shape when you weld it in, even with the proper gap. It's noticeably flimsier than the rest of the panel.
What I should have done is use the original QP marker recess to FLANGE weld the fender piece into the same hole. I didn't do that at first because I was thinking it would be hardto get the fender piece at he exact same depth. Now I'm thinking that wouldn't have been as hard as I thought.
Soo, to fix this I'm going to weld a little reinforcement brace around the marker area to get it to maintain the proper shape.
I did find one other issue with this mod, there is no water seal in the fender markers.
Might not matter for my car as its a fair weather/show car only, but could cause some issues in a daily driver.
I'll get one pics up soon.
Old Sep 12, 2012 | 11:09 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
What you are talking about is called Candying. Go to a place the sells model car paint and get a can of transparent candy red. Spay the amber lense whit the candy red. The light will now light up red with a clear bulb in it. I have done this before and in fact the rear turn signals on my step dad's Hraley are like this and have been for a few years.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Linson
Aug 21, 2015 02:12 PM
z28addict8490
Aug 7, 2015 08:48 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
