Windshield air leak
Old Dec 14, 2000 | 03:27 AM
Alek's Avatar
Windshield air leak
I'm kinda' new here, so no idea if similar question was ever asked. I've got 91 Camaro RS. It's got an air leak on driver's side window. Tried using sealing tape, did not work that well. Anyone's got any idea how to fix that?
Old Dec 14, 2000 | 03:18 PM
KS91Z28's Avatar
You can do a couple of things. Replace your seals, or adjust the window stops so that the window pushes against the seal a little harder.
Old Dec 14, 2000 | 05:33 PM
Josh 91RS's Avatar
Im pissed, my drivers side leaks a little too much air also, and i tried to adjust the stops the other day, but cant get the door panels off because previous owner stripped allen screws holding the window and door lock instruments.
Old Dec 14, 2000 | 09:04 PM
Alek's Avatar
How do you adjust the window stops?
Alek
Old Dec 15, 2000 | 10:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Josh,
Double-check the screws; some are simply plastic manufactured to look like the real thing--indeed, you will round those out. Use a magnetic, if need be.
JamesC
Old Dec 15, 2000 | 10:45 AM
Josh 91RS's Avatar
Thanks james ill give it another look this weekend
Old Dec 22, 2000 | 07:30 AM
FBODY-ADDICT's Avatar
Or outline between the weatherstripping with clear window silicone. Since it will be in between the stripping, its unnoticeable and it will make your window shut tighter when it goes up.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
TheExaminer
Aug 26, 2015 04:59 PM
