Power hatch or Power lock?
Old Dec 4, 2000 | 07:21 AM
Imark's Avatar
Probably a stupid question but here goes. I've got a stock '84 Z28. The console button located between the power windows switch. Is it just a Power truck release or should it release the trunk and operate a Power hatch motor as well? If it's supposed to operate the Power hatch motor...I got problems. TIA
"It's not about going fast all the time; It's knowing you can, anytime"
Old Dec 4, 2000 | 02:43 PM
evilho7810's Avatar
I dont think that 84's came with the hatch motor.
Old Dec 4, 2000 | 05:56 PM
86ZRICHIE's Avatar
it's just to pop it. I don't think they came with a motor stock either, but it could be that it's just a regular lock with the pop actuator on it.
Old Dec 10, 2000 | 04:12 AM
killrog22's Avatar
the switch does opperate the power hatch motor. In 84 the motor was an option.
Old Dec 10, 2000 | 09:46 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Yep! Its a power truck relase! Just like Knight Rider! When you hit that button, a truck will come flying out of the front of your camaro! just kiddin around,
It should be the trunk release. When you hit the button, it should unlock the hatch. Sounds like you got troubles, check the connector at the actual motor to see if it isnt loose...
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 10, 2000 | 10:48 AM
Coolcars's Avatar
The button releases the latch. You may or may not have a power hatch motor. The power hatch motor is not powered by any switch in the car. the motor has a momentary contact switch in the latch itself. when the latch is released the switch opens and the hatch motor comes up. When you close the hatch the switch closes and the motor pulls the hatch down. If you look at the pannel in the back if you have the pull down hatch you will have a contact pad to the left of the hatch as you look into the car from the rear. If you don't have the pull down motor you will just have a slot of the hatch catch. If the switch in the center console is not working there is a relay under the console that could be the problem. Check to see if you have power to the relay if you do you probably have a bad relay.
2E,87 Formula 350, 4 other Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Dec 10, 2000 | 09:49 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I added an interior trunk release to my car over the summer. When I just added the switch (I was prewired from the factory for a trunk release) and hit it, the trunk motor went up and down, but did not release the hatch. I needed the separate trunk popper for that.
Old Dec 17, 2000 | 11:43 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Also remember that the hatch release is tied into the park/neutral safety switch for automatics or the parking brake on a manual car. You don't want to open it at speed.
Old Dec 24, 2000 | 12:47 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
that contact pad is for the third brake light, not the hatch pull down...
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
BRoss99
Aug 10, 2025 05:08 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
