Front bumper cover removal?
Old Jan 7, 2001 | 03:05 PM
leirch's Avatar
I need some help or suggestions on removing the front bumper cover on my 87IROC. Any help would be great
Thanks,
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Old Jan 8, 2001 | 09:00 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
about 6 nuts on inside of each fender...i think a 8mm. probably 4 nuts (2 each side for gfx) size 10mm and should have 8 nuts for bumper connection...13mm
throw in a bunch of little plastic clips and you should just about have it.
Old Jan 8, 2001 | 09:51 PM
leirch's Avatar
Thanks Duff, That should help alot, i have most of the obvious and easy to get to bolts. Just have to get some more time to make it to the garage to rip the rest of it apart.
Brendan
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
transam84
Aug 14, 2015 08:54 PM
