Do you know anything about speedos? Help me as mine is giving me wrong readings.
Old Jan 7, 2001 | 09:04 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
My speedo is reading lower than I am going and have sort of established that it must be one of 2 things.
1. One of the previous owners has changed the rear end gears. If so, how do I find out what they have been changed to? If it is the rear end gears that have been altered where can I get new speedo gears from?
2. The speedo head is buggered. How do I establish if this is actually the case? Also, can the speedo head be replaced and if so how much is it and where from?
Thanks for the help as I really want this problem fixed.
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Old Jan 8, 2001 | 09:51 PM
LottaBallsCamaro's Avatar
I dont know what you mean by the speedo head but if you suspect different gears then you cn do a very simple check with the car in neutral jack the car up by the rearend and while spinnig the driveshaft count how many revolutions you have to make to turn the rear wheel once. There should also be a tag on the rearend that will identify what it came with stock. I'm also nt sure what the codes are but I know that chiltons has them. Hope this helps!!!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Cornholio7979
Sep 20, 2018 02:31 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
GTAman
Sep 21, 2015 09:57 AM
sunbound
Sep 5, 2015 11:52 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
