Center piece!
Old Jan 15, 2001 | 12:42 PM
jeff's Avatar
Center piece!
The center piece below the dash(houses the trunk release, fog lights, and defrost) is hanging down on the right side in my 92 bird. I recently took it off so I could replace the plastic that goes over the speedo. Anyways, could someone tell me if there are 2 or 3 screws holding the center piece up. I have 2 screws for it, and there is a 3rd hole, that is more towards the right side. As far as I can tell that hole is not meant for a screw.
Old Jan 15, 2001 | 03:10 PM
MNformula350's Avatar
There should be 2 on hte bottom and 1 over on hte side where it goes under the other piece under the pouch.
On the T/A's and stuff the other piece has the performance suspension emblem
84 FIREBIRD-2.8 V6,5spd super economy model
no options except t-tops( not even locking),no tilt,no cruise,no delay wipers,no rear defroter,no a/c,no rear spoiler(i put one on)no pw,pdl,pm,pseat,no gauges(just a 85 mph speedo with no trip odometer and a big f***in' gas gauge)
90 FORMULA 350-
Edelbrock t.e.s,gutted cat,Borla cat-back,LT4 hot cam ,24# injectors,holley h.p. fuel pump,K&N Throttle Body mounted air filter,52mm throttle body,accel 8.8mm wires,plugs cap and rotor,ADS superchip,GTA tailights,T-tops,4th Gen 17's with 275/40ZR17 Comp T/A's,93 Z-28 seats
No E.T's yet.
Previous 3rd gen's
83 Trans-Am 305 CFI auto T-TOP
84 Firebird 305 H.O. auto HARDTOP
87 Firebird 2.8 V-6 auto HARDTOP
Old Jan 15, 2001 | 04:00 PM
Drew's Avatar
The accessory switch panel on the 91-92 birds almost never sits right. It should have two 7mm screws and two clips that snap into the guage bezel. If the holes for the clips are broken it won't fit right. Try loosening the screws and tightening them while holding the panel in place... if you overtighten them it won't sit level... loosen the screws till you're happy with it. Also keep in mind that these panels really have a tendancy to warp.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Veaceonee
Sep 29, 2016 08:15 PM
Saxondale
Sep 15, 2015 06:42 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
