headlight relay
Old Jan 16, 2001 | 05:13 AM
elwood ironhead's Avatar
headlight relay
1984 firebird, headlight motors work when hooked up to power supply. won't work in car. Where is the relay located? Thanks.
Old Jan 16, 2001 | 10:47 AM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
There are 3 relays. 1 isolation relay part #10022620, 2 actuator relays part #10031018. The isolation relay is between the battery and the radiator, the other two are on their respective sides on the fender support. keep in mind that all three relays look the same, because there is another relay near the isolation one that is bigger and different shaped. I believe it is the throttle-kicker relay. Good luck,
John
84 Firebird w/ T/A gfx, 350 4bbl (LM1), Non-leaking T-Tops (new rubber all around), Auto, Working headlights (new parts), K&N, 180* thermostat, ram-air hood scoop, flowmaster muffler (yuk), Accel cap & rotor, MSD Super Conductor Wires. Soon: new gray interior, SFCs, poly bushings, WS6 sway bars & springs.
thunder57
Nov 7, 2015 02:28 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
