LS Swap quick fuel power questions
Old Sep 26, 2015 | 08:08 PM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
Donor car is a 1987 TPI, swapping in a 2002 LS1.
I'm using an aftermarket fuse block and relay.
Q1: I would use R9 (Fuel Pump Relay Control [Primary]) From the ECM to signal the Relay on?
Q2. Where would I wire in the fuel pump power wire? I cannot find it anywhere in the C100 schematic.
Thanks a lot.
Attached Thumbnails LS Swap quick fuel power questions-connector_1987_c100.gif
Old Nov 7, 2015 | 02:28 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LS Swap quick fuel power questions
You have ample fuses in the stock fuseblock, why add another?
1) Yes, 12v leg
2) C207 D TAN/WHT
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
