Hatch out of ajustment?
Old Aug 3, 2012 | 09:28 AM
  #51
TWX's Avatar
TWX
Car: 1986 Pontiac Trans Am
Engine: 305 4bbl
Axle/Gears: 2.73:1 open
Re: Hatch out of ajustment?
Mine was a good half-inch or more out, I just adjusted at the hinge by loosening the fasteners, pushing it forward, and retightening. It's more like a quarter-inch now, good enough for the moment.
Old Aug 3, 2012 | 09:38 AM
  #52
82tarecaro's Avatar
I just adjusted mine at the hinge. The best way to do it is to remove the struts and then you can move the hatch where it needs to be. I was initially trying to do it with the struts connected and could not get it right. I took off the struts and got it where it needed to be the first time out.
Old Aug 3, 2012 | 10:02 AM
  #53
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
I had already moved mine forward at the hinge and even checked the body bolts. It was off almost and inch after that. The only way to get it close was to reset the panel.
Old Aug 3, 2012 | 10:04 AM
  #54
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
you didnt have to take the whole hatch off did you? I have been to lazy to do mine because I know that glass weighs a TON if i have only one side out of wack could I just remove that side and slide that side of the hatch up and readjust?
Old Aug 3, 2012 | 10:05 AM
  #55
Car: 92 Camaro RS
Engine: 305 TBI
your hinges might be bent I heard they bend too.
Old Aug 3, 2012 | 10:33 AM
  #56
Car: 1988 GTA
Engine: 400 CI
Correct. You don't have to take the hatch off to adjust it at the hinges. But you will have to disconnect the struts from the hatch or when you loosen the hinge the hatch will be pushed back but them.
Old Aug 3, 2012 | 10:34 AM
  #57
Car: 1988 GTA
Engine: 400 CI
I have louvers and my hinges look good. If I bent them any my louvers would hit the body when opening the hatch.
Old Aug 5, 2012 | 10:07 AM
  #58
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
We just have to remember we're working with a pinch welded mass produced car built mostly in the 80s. Things not lining up perfect is normal.
Old Aug 5, 2012 | 07:18 PM
  #59
TWX's Avatar
TWX
Engine: 305 4bbl
I can accept a quarter-inch or less, even if I'm not exactly happy about it.
I have a much harder time when the discrepancies are so great that possibly the hatch won't latch down when closed...
Old Aug 5, 2012 | 07:22 PM
  #60
Car: 1988 GTA
Engine: 400 CI
Old Aug 7, 2012 | 10:04 PM
  #61
mich2112's Avatar
Car: 1991 Z28
Engine: 350 L98
Axle/Gears: G92 - 3.23
Originally Posted by lowbird
Anyone else have this happen to them? The hatch seems to back away form the glass more and more as the years pass. It looks like there is no ajustment?
My 91 Z28 looks the same as yours. I think I need a combo of glass to hinge adjustment and the bottom panel adjustment.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
