Trunk Pop Button?
Old Jan 18, 2001 | 01:30 AM
1989CamaroRs's Avatar
Trunk Pop Button?
were on the dash was this located on a 3rd gen camaro? And what power source would i want to use if i were to hook one up
Old Jan 18, 2001 | 01:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On the console just aft of the shifter. I don't have a wiring diagram handy so I can't tell you for sure where to get power from.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 385 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Because you can always sleep in your car, but you can't drive your house.
Old Jan 18, 2001 | 11:46 AM
Drew's Avatar
You've probably already got the wiring. You'd need a switch from GM, a horn relay, and the hatch release solenoid. Read my tech artical in the tech section of this sight. It won't be exactly the same but most of it will be.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6
92 S10
98 Grand Am GT
Old Jan 19, 2001 | 10:52 PM
camaro 22's Avatar
more detail on location is in between the power window buttons on your center console.
Old Jan 20, 2001 | 12:23 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Power windows? What are those?
Old Jan 20, 2001 | 01:42 AM
AustinT's Avatar
Here is a pic for you. The console is apart right now because im swapping trannies. anyways The 3 buttons control the windows the middle is the trunk release.
<img>http://www.geocities.com/camarodan2001/Mvc-001f.jpg</img>
Old Jan 20, 2001 | 01:53 AM
AustinT's Avatar
Whoops Just go to http://www.geocities.com/camarodan2001/index.html
RS Reaper
Oct 17, 2018 07:52 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
